mk1-forum.net
It is currently Fri Feb 22, 2019 5:54 am
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Wed Jul 07, 2010 4:15 pm
Offline
Anybody any suggestions on a suitable crinkle paint to finish my heater box and best way to apply it?Also the stickers that say car, off etc. Cheers
_________________
Top
 Profile
PostPosted: Wed Jul 07, 2010 5:29 pm
Offline
I've tried "Hycote" Wrinkle finish with success on several parts, from the rocker cover to the dashboard.
_________________
almondgreen.net
My FLICKR
Top
 Profile
PostPosted: Wed Jul 07, 2010 5:46 pm
Offline
I've tried VHT wrinkle spray cans. With variing results. Smal parts are OK, but I found it difficult to get an even wrinckeling effect on large surfaces. Also it seems to be very dependent on how many layers you applie and how fast it dryes (temperature) and how strong the layers are. And the time between layers.
3-4 coats and low temps (winter):
http://img375.imageshack.us/img375/5237/wrinckle3.jpg
5 coats, spring:
http://img203.imageshack.us/img203/7683/wrinckle2.jpg
http://img130.imageshack.us/img130/7691/wrinckle5.jpg
(not satisfied with that, very uneven)
5-6 very thick coats, room temperture - took over a month to fully dry :mrgreen: (without artificial heat):
http://img686.imageshack.us/img686/9516/wrinckle1.jpg
2 thin coats in hot summer day:
http://img130.imageshack.us/img130/3439/wrinckle4.jpg
None of these were put in the oven to dry. So i'm in for hints & tipps as well :)
_________________
You can't have too many cars. Just too little space...
Top
 Profile
PostPosted: Wed Jul 07, 2010 6:00 pm
Offline
Hy cote I had different results probably due to temp and patience for the letters my mate has just done his using letraset
Top
 Profile
PostPosted: Wed Jul 07, 2010 7:07 pm
Offline
I also used VHT wrinkle plus paint and controlled the wrinkles with heat. I tried the oven, but you get the wrinkles too tight, but if you use an heat gun (used to remove stickers or similar) you can control it well and make a similar look to original paint. An air dryer will work too I guess, but will take longer...
Normally I apply 2 to 3 light coats of paint and then warm the parts a little bit. After 1 or 2 hours I heat them again until the desired wrinkle finish appears. Here is my wiper motor:
Top
 Profile
PostPosted: Wed Jul 07, 2010 7:54 pm
Offline
I use the textured paint they use on bumper repairs
James
Top
 Profile
PostPosted: Wed Jul 07, 2010 10:13 pm
Offline
I've had good success with using a heat gun too,
not a great pic unfortunatly, but this in my intake plenum done in wrinkle,
Top
 Profile
PostPosted: Wed Jul 07, 2010 10:25 pm
Offline
WTF is that??? It looks wild
_________________
Top
 Profile
PostPosted: Wed Jul 07, 2010 11:23 pm
Offline
Looks like a Akm 7 port with a big, make that bloody big turbo ! :shock:
Top
 Profile
PostPosted: Wed Jul 07, 2010 11:40 pm
Offline
LOL
yeah thats about the size of it....
for anyone interested its a minisport 7 port head, 37x31 valves, home made injection intake and exhaust manifolds, garret GT25v turbo (variable vane so it boosts from sub 2000 rpm), bottom end is a 1380 with a billet crank, powermax pistons dished to 17cc, piston oiljets from a Zetec, straight cut box, ATB diff, megasquirt ECU.
it was quite brisk on 18psi, but due to a broken cam belt its currently out of action :roll:
Top
 Profile
Who is online
Users browsing this forum: steve and 19 guests
Search for:
Jump to:
