twin tank venting
Re: twin tank venting
That's a right bugger if you have welded up the factory holes Gordon :(
The radiator overflow clip has teeth to grip onto the cowling, in a similar way to the side to side brake pipe clip on the front subframe.
Anyone able to post up a pic of the back of the clip ?
gogsymac
Post by gogsymac »
Andrew1967 wrote:That's a right bugger if you have welded up the factory holes Gordon :(
Not the first time I have welded up holes that should be there. You learn as you go along I suppose.
We've all done it, but at least you can re-drill when the faux-pas is discovered :oops:
Me too, less annoying than the two holes I didn't get welded up where the old rubber handle thingy kept the racing fibreglass boot (with no handle) closed! I am putting grommets in mind you as when all said and done, it is part of the car's history.
Johnny
Post by Johnny »
Here is the back side of the clip, I pushed it out of the hole. This is the lower one. Seems to have dissolved the old vent tubing and bonded together with the remnants. Not a very good venting system.
Thanks Johnny, I'll have a look and see what I've got over next couple of days or so.
Certainly looks sort of familiar ...
gogsymac
Post by gogsymac »
Andrew1967 wrote:Thanks Johnny, I'll have a look and see what I've got over next couple of days or so.
Hopefully you do have something like that in your stash of parts. I would certainly be interested if you do.
steve1071
Post by steve1071 »
Anyone know the change over date from the bolted clips to the welded tabs?
360gts
Post by 360gts »
steve1071 wrote: Thu Apr 08, 2021 9:02 am Anyone know the change over date from the bolted clips to the welded tabs?
Here are some pictures of my Nov 5 built 1275...(complete with factory paint runs).....has the slide in clips.
I suspect that these were eliminated and welded tabs were fitted with the introduction of the RH tank as standard equipment in Jan. 66
P/N 13H9524.....I have a sneaky suspicion that this clip was something that was used on other vehicles. I seem to recall seeing them ...somewhere!
The fact that they appear to be painted green....perhaps they were used on the Lan Rover....just a thought!!!
Pretty sure BMC wouldn't have produced the clip for a small number of RH tank cars.
These small clips and the like wouldn't have been manufactured by BMC but very probably brought in from a small press shops. I know that this is true of a similar round spring clips, also painted green (and blue for the larger size!) used to hold the fuel hoses on MG cars
