Avon Safety Wheels
111Robin
Re: Avon Safety Wheels
Post by 111Robin »
Speak to Steve at Speedshack, he knows his nuts!!
colonel mustard
Post by colonel mustard »
Many thanks.
GraemeC
Post by GraemeC »
From that photo they look like a standard radius seat?
LuisM
Post by LuisM »
Did we ever find out the type of wheel nuts used on these wheels or where to get them from?
i've ended up by not figuring out that, but still have the wheels and i have now a good variety of wheel nuts, will try some over Christmas.
Luis
LuisM
Post by LuisM »
Hello,
I was testing all my wheel nuts on an Avon wheel , the rover Cooper/sportspack wheel fits nice and tight ( nut on the right side , 3rd pic ) , I’ve tested Minispares part number NAM9075 but the “cover less” AJM1139 nuts should be a better bet .
Merry Christmas
Luís
colonel mustard
Many thanks Luis,
Merry Christmas.
Pre Christmas I spoke speedshack and they have recommended these nuts:
Started to have a go at refurbishing myself (not much else to do during lockdown!)
Good clean down and paint stripper
Filed down the badly kerb rash and worked through a selection of sand paper grades (240-2500 wet and dry)
colonel mustard
And some more
Bit of masking time
On with the etch primer
Then started the satin black alloy paint, still more coats to go
colonel mustard
And more
LuisM
Post by LuisM »
Very nice job!
How did you filed down the kerb marks ? They came Really nice .
Reg the nuts , if you check my pic I’ve also tried same nut as the ones advised by speedshack , they might suit , although felt them a bit loose. the rover ones fit much better and give better support.
That’s what I will buy .
Luís
colonel mustard
Thanks Luis
I just used a hand file to take the worst off then used a flapper in the drill to take back further defects before using the drill sanding disc up to 800 grit then hand wet and dry up to 2500grit.
Tricky rims to work on, especially the triangular sections.
I am hoping to do final sand once the masking tape is removed.
