Has any one used one of the products out there?, opinions (good or bad) please
![Smile :)](./images/smilies/icon_e_smile.gif)
I am not so sure about what the definition of "performance" here would be...olddad wrote:the engine can be run at higher temperatures if you want to,
for performance purposes, without boilover.
In the shed wrote:Big bore minis are already running hot.
Putting something with a lesser specific heat capacity figure in it is akin to blanking off bits of your radiator. It may boil higher, but since the ideal running temp is already exceeded in many minis, this is counter productive.
It's snake oil of the worst sort.
You want 100% water, in an ideal world.
....Wow !! some good tech points made !....I was getting very exited and then thought !!?? wait a minute.. my mini always has had 100% water..no overheating ! no issues ever..only flushed every 7 years....occas top up yearly with a dash of Glycol for the freezing weather...if I drain it out and refill it with water once a year like an oil change is that beneficial ??or do I not bother cos if it aint broke why try to fix a problem that doesn't exist ??.... so +2 for 100% water... foxy52minimans wrote:In the shed wrote:Big bore minis are already running hot.
+1 for 100% water and a bottle of Water Wetter, here in California it works just great in all my cars and my customer cars. In the UK or cold climate you could use a 10 to 20% glycol mix in the winter and still retain the benefits.........Paul
You really need to add some sort of water wetter or a small amount of glycol to help prevent rust and electrolytic action on the dissimilar metals I'm not sure I would want to use just water on it's own and then not change it for a couple of years!foxy52 wrote:....Wow !! some good tech points made !....I was getting very exited and then thought !!?? wait a minute.. my mini always has had 100% water..no overheating ! no issues ever..only flushed every 7 years....occas top up yearly with a dash of Glycol for the freezing weather...if I drain it out and refill it with water once a year like an oil change is that beneficial ??or do I not bother cos if it aint broke why try to fix a problem that doesn't exist ??.... so +2 for 100% water... foxy52minimans wrote:In the shed wrote:Big bore minis are already running hot.
