door frame finishing surround
devoys 997 cooper
Post by devoys 997 cooper »
originally the door window frame surround was fixed in place with metal clips which went in the door frame holes and bent at a right angles. while i was at bingley hall show i went to somerford minis stall with one of these clips they said they had not seen this before and gave me some rivets. these are far too small for the holes in my door frame which are approximatly 5mm in diameter. unfortunatly i have scince lost this clip has anyone seen this before and does anyone know where i can get some of these clips.
66S
Re: door frame finishing surround
Post by 66S »
It looks as if someone has drilled the fasteners out (to remove them)with an oversize drill.
Al
ricardo
Post by ricardo »
I would say this is an early door which has bigger holes for clips instead of rivets. I don't know where you can buy the clips.
devoys 997 cooper
hi al, i took the trims off and the clips i mentioned before were in place they seemed to be original to me ,they was no damage to the window channel or any signs of touching up which would have been evident if they been drilled out previously,regards mark
Gray
Post by Gray »
Have a look through the line up these guys have: http://www.bresco.com/
guru_1071
Post by guru_1071 »
they are the holes for the early type slide in clips, im not sure they are still avalible?
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
I know a guy who has some of the original clips you are after (it is an early Cooper door BTW). If you get stuck send me a message and I will speak to him. Cheers. Mark
My 1071 had holes that size, when I restored it the clips were still a BMC off the shelf part. I haven't seen any for a good few years now though.
I'll have a rummage & see if I can find any.
steve1071
Has thanked: 17 times
Been thanked: 16 times
Post by steve1071 »
What build date was yours, Mark?
It was a very early Flat blocked one.
Has thanked: 261 times
Been thanked: 230 times
Yes, I have also had Mini's with this style of window trim clip.......used to order them from local my BL Dealer back in the 1970's. Then they became NLA.......
