AEG 151 block question
swifty
Been thanked: 34 times
Post by swifty »
Hi I have a block for sale AEG151 . It has bolts to hold the main caps on . Is this correct or should it have studs and nuts... or either ? ... ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
carbon
Re: AEG 151 block question
Post by carbon »
The early 1071 blocks used bolts, if they are correct type there is a raised 'dowel' section on the bolt above the threaded section which locates the main caps.
If you have the correct bolts don't lose them.
App K
Post by App K »
I have a 151 FJ block with studs and nuts.
251 ENG
Post by 251 ENG »
Early blocks have fitted bolts that are unique to the 1071 .
Later block have studs .
They are not directly interchangeable because the location diameters are different sizes
Approximately the first 2700 blocks have bolts
App K
Post by App K »
251 ENG wrote:Early blocks have fitted bolts that are unique to the 1071 .
Is that including the AEG 151 FJ blocks? Or are they not recorded?
It may be that mine have been replaced at some time.
swifty
Post by swifty »
Thanks for reply s .. ken
Porsche 997 turbo S
I am from Essex
251 ENG
Post by 251 ENG »
Yes that figure includes FJ blocks .
The location diameter is bigger on studs so you have to machine down to suit early blocks .
Or open out block and cap locations if you want loads of work .
