Roger
Many thanks - that figures now ! Part number of the 'block' is 22A1715. I've got a 4-synchro magic wand gear lever somewhere. Don't recall ever having the pressed plate that goes in place of the remote arm though.Vegard wrote:4sync Magic Wands basically.
For ref : The 'Seat / Locating foot' attached to my housing is numbered 22A1715, so I assume this is another of those MOWOG numbering wobbles where the number on the item is a casting number, and 22A1832 is actually the assembly. I'm guessing there should also be a sprung pin in the middle of the foot to locate in the gearlever keyway, which as you say has it on the top not side as 3-synchro.mab01uk wrote: <snip>
2A3467 Bush
2A3390 Spring
22A1832 Seat / Locating foot
88G553 Selector shaft
22A1717 Cover
22A1382 Gearlever 1968-75 (Later type wand with slot at the top of ball)
<snip>
Diagram:
http://www.somerfordmini.co.uk/eshop/in ... age&id=151
would that still be a 22g1128?rich@minispares.com wrote:you could also get a normal 4 sync magic wand box
probably easier to find than the rare remote conversion
technically yes, but it has a magic wand back on it from the factorydocka wrote:would that still be a 22g1128?rich@minispares.com wrote:you could also get a normal 4 sync magic wand box
Presumably using the same rear casting as the 3-syncho boxes Rich - So if it's different is the casting number known on this variant and is it a matched line bored pair like the 3-synchro boxes, or are the rears interchangeable like the other 4-synchro boxes?rich@minispares.com wrote:docka wrote:rich@minispares.com wrote:technically yes, but it has a magic wand back on it from the factory
If I am understanding this right Rich, you're saying this has a diff cap similar to the 3 Synchro Magic Wand?rich@minispares.com wrote:technically yes, but it has a magic wand back on it from the factorydocka wrote:would that still be a 22g1128?rich@minispares.com wrote:you could also get a normal 4 sync magic wand box
There's a pin, but its rigid not sprung. Its common for the pin to wear, often to the point that it breaks off. This can make changing gears somewhat challenging, as the gear stick will flop around all over the place. I've seen them missing entirely, with just a ridge worn into the alloy foot doing the work.dodge44 wrote:...I'm guessing there should also be a sprung pin in the middle of the foot to locate in the gearlever keyway, which as you say has it on the top not side as 3-synchro...
