Gear Linkage Bush
docka
Gear Linkage Bush
Post by docka »
Is there a replaceable bush in here? seems quite a lot of movement, even for a remote/wand conversion...
if so, does anybody know the part number and what's it like to change?
CooperTune
Re: Gear Linkage Bush
Post by CooperTune »
2 A 3502 MSC two each. Steve (CTR)
docka
Post by docka »
Cheers. Are they difficult to swap out?
Has thanked: 142 times
Been thanked: 122 times
Isn't there a round oil seal in there too as I recall? You'll also need a new grease nipple too as the head part of the one shown has been knocked off. That could be the reason why the shaft is so loose
Has thanked: 187 times
Been thanked: 65 times
docka wrote:Cheers. Are they difficult to swap out?
Been a while since I last did these, but I cut a thread in the old bush and then pull them with the slide hammer.
Peter Laidler wrote:Isn't there a round oil seal in there too as I recall?
The Oil Seal is on the shaft going in to the main part of the case ;)
Yep....., you're right as per usual Chris. I seem to recall that unless the grease nipple teat thinggy is set at the right angle, it's impossible to click a grease gun onto it, hence the fibre washer that enables you to position the nipple. And you know how frustrating it can be not being able to click onto a nipple
Peter Laidler wrote:Yep....., you're right as per usual Chris. I seem to recall that unless the grease nipple teat thinggy is set at the right angle, it's impossible to click a grease gun onto it, hence the fibre washer that enables you to position the nipple. And you know how frustrating it can be not being able to click onto a nipple
Yes, quite Peter. Originally, they didn't have any grease nipples at all !!
And if I recall the workshop manual states that these should only be greased at times of 'major overhaul' :lol:
The bushes are available from Minispares etc, but do need sizing on the ID.
rich@minispares.com
Post by rich@minispares.com »
they are a swine to get out as you cannot get them out with a slide hammer or a punch.
this is how I do them
drill them and tap them 5/8 unf
then screw either a allen stud in or i use the bango bolt from a oil pipe as the punch sits inside it nice
knock them out
refit the others using a stepped punch in tool (made from an old adjustable tie bar)
the standard replacements you can get shouldnt need sizing to the normal shafts, a lot of the shafts are really worn, so its possible to get undersize bushes that then need line reaming to suit, but i doubt that makes that much difference
docka
Post by docka »
Thanks for the advice guys, i'll give Rich's method a go...
Meanwhile, where do these bits go then?
They came with the remote/wand conversion bits from Minimail...
rich@minispares.com
They go in the female knuckle and stop it ratteling
docka
Post by docka »
rich@minispares.com wrote:They go in the female knuckle and stop it ratteling
In the smoking pipe part?
rich@minispares.com
yes
they don't all have them, I think it might have been a ado16 part, but I always fit them if I can find them as it takes a little bit of the slack out of the linkage
rich@minispares.com wrote:they are a swine to get out as you cannot get them out with a slide hammer or a punch.
Sure, they are tight, but I've never had trouble with the slide hammer, 2 or 3 hits and they're out.
rich@minispares.com
i find that as the are butted up to the alloy case, there is no space to get the decent slide hammer attachement 'hooked' over the end of the bush
my other slide hammer that is like a rawl bolt sort of thing that grips the walls of the bush tends just to slide out as the material is so soft - plus you end up punching yourselt in the face with the slide hammer (or is that just me!)
much easier to quickly tap them and knock them out!
what ever method used, they are well worth swopping
Ah, OK,,,,
I have a fitting that I can use various sized bolts on it ;)
what ever we all used to working with :)
docka
Post by docka »
rich@minispares.com wrote:yes
Cheers, it seems a very tight fit...
Jim1071
Post by Jim1071 »
knock them out
I put the new bushings in from mini spares and found they move in the bore
so I had to remove them wipe clean and use epoxy them
1964 Austin Cooper S 1071cc april
1964 Austin Cooper S 1071cc june
1967 Austin cooper S vintage race car 1293
1978 Austin Mini 1000
1999 Mayfair Rover 1275 spi
