mk1-forum.net
It is currently Mon Feb 17, 2020 5:23 am
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2, 3  Next
Author Message
PostPosted: Fri Jan 24, 2020 5:05 pm
Offline
Where does the water exit the inside of scuttle panel/bulkhead after entering the central grilles ?
Top
 Profile
PostPosted: Fri Jan 24, 2020 9:08 pm
Offline
Andrew, the water drains to a rectangular cut-out at the front of the outer sill and the bottom rear of the front wing. Many who restore the ADO16 close this original cut-out and water then builds up inside the bulkhead double skin and that is trouble right away. :)
Alan
Top
 Profile
PostPosted: Sat Jan 25, 2020 10:06 am
Offline
This is the drain point in the inner wing that Alan is referring to. For me it is worth making an inspection/cleaning/wax treatment hole as it is shown in the second photo.
Top
 Profile
PostPosted: Sat Jan 25, 2020 10:51 am
Offline
Thanks for those posts, I'll have a look on the VDP and see what I can see. :)
Alan, are you talking about the area directly below the A post where the sill ends and the wing fits up to. Seems like there is a vertical void between the A post and wing which goes right up to the scuttle corner. Will take some photos to explain.
Top
 Profile
PostPosted: Sat Jan 25, 2020 1:59 pm
Offline
Found the drain holes .... :)
Top
 Profile
PostPosted: Sat Jan 25, 2020 2:00 pm
Offline
Alan, this is the part of the A post I was referring to, should there be a drain hole at the bottom of the A post ?
Excuse the photo orientation :oops: :roll:
Top
 Profile
PostPosted: Sat Jan 25, 2020 11:32 pm
Offline
I don't have any photos of mine finished in this area Andrew, only during repairs so not sure if they will help but you can see the opening at the end of the sill.
Image-20171026_200950 by Robin Derrick, on Flickr
Image-20170929_121514 by Robin Derrick, on Flickr
Top
 Profile
PostPosted: Sat Jan 25, 2020 11:36 pm
Offline
Interesting Robin.
So it looks as though there is a BIG hole there. The end of the sill is blanked off where it ends.
That is useful ... thanks :)
Top
 Profile
PostPosted: Sun Jan 26, 2020 12:01 am
Offline
The end of the sill isn't blanked off, it's the bottom of the A post that is solid The sill sits on top of the A post and is just spot welded along the bottom edge at the front. The nose of the sill tucks in between the A post and the bottom corner of the wing. The sill extends about an inch beyond the bottom of the A post.
Image-20180315_173612 by Robin Derrick, on Flickr
Image20180315_173620 by Robin Derrick, on Flickr
Top
 Profile
PostPosted: Sun Jan 26, 2020 12:10 am
Offline
That could be my mistaken interpretation Robin, will look at the car tomorrow.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
