mk1-forum.net
It is currently Wed Jul 18, 2018 10:43 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
PostPosted: Fri Dec 01, 2017 12:18 pm
Offline
I know one was Alegro!!!
Top
 Profile
PostPosted: Fri Dec 01, 2017 7:42 pm
Offline
rich@minispares.com wrote:
the 22g2093 (right hand) is the same part number as an allegro
just bought one off ebay, so that's half way there!
Allegro :lol: :lol: :lol: Bejesus you'll be wanting SQUARE steering next :lol: :lol: :lol:
Top
 Profile
PostPosted: Fri Dec 01, 2017 8:44 pm
Offline
I have a related question: are the rubber joint and auto (hardy spicer) ones of the same length? I was thinking of using hardy spicer replacements (fitted to rubber joint shafts as would go on a Mini). They differ however in length on a Mini. However, if Rich gets pot joint ones to become available from MiniSpares, I might be your first customer for a LH one :)
Perhaps the value of allegros has just doubled :lol:
Edit: I just realised that the RH shaft would be the one to solve one of the more 'urgent' issues with the ADO16 rubber joint setup as at this side the rubber joint joke seems to like eating up the gearbox casing/clutch housing... So, one could have pot joint on the RH side and a rubber at the LH side. Not really my preference but it would work
_________________
1964 Austin Cooper S 1275
1965 Volvo Amazon Combi
1965 Austin Cooper 998
1967 Morris Minor 1000
1967 Austin Cooper 998 Mk II
1969 Austin Cooper S 1275
1972 Austin 1300GT (2x)
1975 Mini Jubilee
1978 Mini 1000
1991 Rover Cooper (Carburettor)
Top
 Profile
PostPosted: Sat Dec 02, 2017 12:18 pm
Offline
How are you doing on the other one Rich - 22G2092
Maybe an offer of a s/hand one on FB - should I pursue it?
_________________
David - chairman@ado16.info
1968 MG 1300 Saloon Connaught Green
1972 Triumph 2.5 PI Estate Royal Blue
1978 Carlight Casetta Caravan
http://carlightrestoration.blogspot.co.uk
1995 Lada Riva 1.5 Estate Cherry
Top
 Profile
PostPosted: Sat Dec 02, 2017 1:52 pm
Offline
david
I will take what I can
I just want to be able to measure all the manual and auto ones to see what is what
I think the pot joint ones will be the same for either
_________________
Top
 Profile
PostPosted: Sat Dec 02, 2017 9:28 pm
Offline
I'll see what I can do Rich
Mini4Ever - on a car with the donuts the drive shafts are different lengths for the automatc - but I don't know when it comes to pot joints; I'll try to find out. :)
_________________
Top
 Profile
PostPosted: Sun Dec 03, 2017 6:18 am
Offline
The Australian parts book lists the same driveshafts for both the Manual and the Automatic.
17H8598 = RH
17H8599 = LH.
Top
 Profile
PostPosted: Sun Dec 03, 2017 10:21 am
Offline
17H8598 = RH
17H8599 = LH.
I'm going to blame Simon..... spares@ado16.info :roll:
It's the whole assembly that is different, not the actual main driveshaft! ...so you're quite correct Seamist Green 1100
_________________
Top
 Profile
PostPosted: Sun Dec 03, 2017 1:21 pm
Offline
Great 8-) Hardy Spicer rules :lol:
Pot joint drive shafts will for sure be different at the gearbox end.
Perhaps the following is a reasonable approach for pot joints. Measure the difference in length for the RH pot joint shaft and a normal RH pot joint shaft. Assume this difference translates to the LH side. Cut the gearbox end off a standard LH shaft and do the same for a pot joint shaft of a Mini such that the total length after welding the Mini bit to the cut ADO16 LH shaft matches what was computed based on the assumption. Hope this makes sense.
_________________
1975 Mini Jubilee
1978 Mini 1000
Top
 Profile
PostPosted: Sun Dec 03, 2017 1:27 pm
Offline
I don't think there will be different lengths for the pot joints ones as the joint is able to cope with more movement than a rubber cross so it makes sense that the same shaft could be used on both auto and manual
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
