mk1-forum.net
It is currently Wed Jul 18, 2018 6:01 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: What's This Axle From?
PostPosted: Sat Jul 22, 2017 2:08 pm
Offline
Hopefully this fits here.
So it's very un-mini and far earlier than what I'm used to working on but I was hoping with the myriad of knowledge on here someone might know what it's from. I was told it was Ford but I've not been able to find anything similar.
Top
 Profile
PostPosted: Thu Jul 27, 2017 5:31 am
Offline
Possibly MG?
What diameter are those drums? It might give a good indication of the era.
Looks Post war, but before the 60's.
Top
 Profile
PostPosted: Thu Jul 27, 2017 5:37 am
Offline
Big Healey?
Top
 Profile
PostPosted: Thu Jul 27, 2017 10:49 am
Offline
69k1100 wrote:
Possibly MG?
The internal diameter on the drums is 11 3/4" and the PCD on the studs looks to be 4x 5 1/8".
I've looked at a few big Healey axles but they all have parallel leaf spring mounting where as my axle has angle ones.
Top
 Profile
PostPosted: Thu Jul 27, 2017 10:54 am
Offline
The axle also came with a pair of cast aluminium brake backplates which are the same design as the pressed steel ones currently fitted.
I'll get some pictures of them up later.
Top
 Profile
PostPosted: Thu Jul 27, 2017 11:23 am
Offline
there is no way that's big Healey
its a pre war (or a post war car designed pre war) as its cable or shaft brakes
its also upside down in your photo, it will sit on top of the springs
its certainly not model t or model a ford
I would guess that's its off a 'cheaper' car due to it having bolt on wheels, but the alloy backplates will suggest a sporting model, though a fancy sporting model would probably have an alloy diff carrier as well.
I think I would pull the diff out and see what marks are on that
_________________
Top
 Profile
PostPosted: Thu Jul 27, 2017 12:17 pm
Offline
It's definitely mechanical brakes rather than hydraulic. I've pulled the cover off the diff and there are a few markings but nothing obvious. I'll throw some pictures of those up with the backplates.
Top
 Profile
PostPosted: Thu Jul 27, 2017 9:30 pm
Offline
Here are the alu backplates and gear markings. I also pulled off all of the lock tabs to see if there were any more markings behind them but there was nothing extra.
Top
 Profile
PostPosted: Fri Jul 28, 2017 10:04 am
Offline
Ok, Best and final guess.
Essex super 6.
http://www.pinsdaddy.com/1925-essex-six ... m5GmSyMPA/
It could be wrong, but may at least point you towards some people who might know.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
