mk1-forum.net
It is currently Mon Apr 22, 2019 9:05 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Mk1 Wolseley 1100
PostPosted: Wed Feb 15, 2017 9:37 am
Offline
Did the Wolseley 1100 have the same engine spec' as the MG ?, ie. 12G295 and twin SU's ?.
Top
 Profile
 Post subject: Re: Mk1 Wolseley 1100
PostPosted: Thu Feb 16, 2017 1:24 pm
Offline
Think it may have been a single carb...
Top
 Profile
PostPosted: Thu Feb 16, 2017 2:11 pm
Offline
I'm sure my '67 Wolseley I owned in the early '90s had a single HS4 carb, but I maybe mistaken as the Wolseley did not have the Cooper type air cleaner.
But if you look at the brochures on this link it shows twin carbs
http://www.ado16.info/brochures.php
Top
 Profile
PostPosted: Thu Feb 16, 2017 5:58 pm
Offline
Thanks. The photos I've seen do show twin carbs but with a central cylindrical filter box, not like the cooper so at a quick glance you might think it to be a single carb.
Top
 Profile
PostPosted: Sat Feb 18, 2017 1:38 pm
Offline
Robin,
The Wolseley 1100 was first produced in September 1965 and had the identical engine and gearbox as the MG / Riley Kestrel and Vanden Plas 1100 with twin carburettor application. The 1098cc Wolseley engine had the 12G295 cylinder head and high compression pistons and AEA630 camshaft that can be identified by two rings near to the large bearing journal end of the shaft. This is the same camshaft as the 998 Mini Cooper. This block is identical to the Mini 998 engine, just a change of crankshaft and pistons. The very early MG 1100 engine of 1962 had a cross-drilled crankshaft and used the 997 Cooper camshaft which has one ring and is a fantastic cam. This early MG 1100 engine had the 12G206 cylinder head which had retained the standard inlet valve size, however it benefited from improved porting and inlet manifold locating rings for the twin carburettors.
Hope this is helpful.
Alan
Top
 Profile
PostPosted: Sat Feb 18, 2017 8:44 pm
Offline
Thanks Alan,
I was looking at a nice original Mk1 Wolseley but it was too high an asking price for me unfortunately
Top
 Profile
PostPosted: Tue May 09, 2017 7:09 pm
Offline
That's great info Alan. I have just dismantled my MG1100 engine/transmission to refresh. I believe it is an early MG1100 engine as it has the 206 head with larger valves (used on the 998 Cooper?), 5 ring pistons (which are +20 so not original) and a TWO ring camshaft. Unfortunately, the engine was a "period" upgrade to my 1960 Mk 1 mini 850 and is missing its engine number so I have no way of guessing its age. As for the transmission...3.1FD, rubber drive joints replaced with nylon, roller bearing units, magic wand shifter.....the guy who modified it knew his stuff but the problem is that a full tear down is needed to find out what was done.
I always find that taking apart these old cars is a bit like industrial archeology or even more like the Forrest Gump quote "life is like a box of chocolates - you never know what you are going to get".
Steve
Top
 Profile
PostPosted: Tue May 09, 2017 7:13 pm
Offline
...I should also mention that my car is left hand drive and I believe the MG1100 had a single HS4 SU carb - at least here in the US, though mine had been fitted with a nice aftermarket intake and exhaust headers to squeeze it into the mini
Steve
Top
 Profile
PostPosted: Wed May 10, 2017 10:00 am
Offline
As far as I was aware even US-spec MG 1100 cars always had twin SU HS2 carbs., certainly confirmed by all the literature I have....the only time a single carb appeared on an ADO16 MG was when the 12G engine was installed or 1300 automatic was specified.
_________________
David - chairman@ado16.info
1968 MG 1300 Saloon Connaught Green
1972 Triumph 2.5 PI Estate Royal Blue
1978 Carlight Casetta Caravan
http://carlightrestoration.blogspot.co.uk
1995 Lada Riva 1.5 Estate Cherry
Top
 Profile
Who is online
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
