crackle black paint tip
pad4
Post by pad4 »
if youre painting something with crackle black paint you get fantastic results if you just stick the fresh painted part in a hot oven about 100 deg c, crackles and dries in 10 mins but do it when the wifes out cause it stinks
minitravellerman
Re: crackle black paint tip
Post by minitravellerman »
When I last painted with the crinkle finish I set the freshly painted item beside a halogen heater for a 1/2 hour or so - came up with really good finish as well.
Ian Campbell
tjw89
Post by tjw89 »
Also if you have some infra-red lamps, they work very well everytime for me, probably more because of the amount of times I have used the stuff.
nippycars
Post by nippycars »
whats the best one to use?
Website now LIve, www.nippycarsonline.com
ChrisB
Post by ChrisB »
Make sure you set a timer, my Dad blew up the garage a few years back when he left a paint can on top of a Halogen heater. Blew the back doors apart, bent the metal front door, smashed most things in the garage and lifted the roof beams.
"whats the best one to use?"
I have had consistently good results with the VHT crackle paint & consistently bad results from the HYCOTE variety.
mini13
Post by mini13 »
another vote for the VHT one here, Ive got good results by preheating the part, the heat lamp does sound like a good bet too, I'll have try that,
it does Pong though...
tjw89
Post by tjw89 »
Crackle balcked another rocker cover yesterday, and it looked great, the person I sold it too was well chuffed with the final thing. VHT is the one to go for.
nippycars
Post by nippycars »
got some VHT, very pleased with the results, thanks.
YMJ
Post by YMJ »
Any advice for someone who bought a can of HYCOTE before this thread was started? :roll:
tomkidd
Post by tomkidd »
I just paint with the VHT stuff from Frost and leave it... crackles up fine without being in the oven etc
tedmcedd
Post by tedmcedd »
VHT from frost is what I use...
I've used a Hot air gun in the past which works well, but Ive also left it overnight with similar results...
miniminor
Post by miniminor »
I could do with painting my heater to smarten it up, looking somewhat tatty and letting down the rest of the interior. Where do I get the Car / Screen / Off decals or transfers from to replace them after repainting?
2014 Freelander 2 SD4
5portsrock
Has thanked: 10 times
Post by 5portsrock »
Hi,
just used the vht on the ears and it works great. :D
Does the front panel where the decals go get crackle finish as well ???
Hipwell
Post by Hipwell »
Yup does.
5portsrock
[quote="Hipwell"]Yup does.[/quote
Great stuff. Thanks for the speedy reply
850man
Post by 850man »
I use a heat gun, its even quicker than the oven!
VHT is the best.
